Root [THEME] ICS/JB-BROKEN OUT Theme *7/10/12*
Runs beautifly.. nly minor thing os the text in the status bar and.in other areas is the same colot as the bavkground. I'm not sure of that was intentionally done... anyways awesome. Hopefully broken out doesn't reboot every20 mins again...
Absolutely amazing, well done sir!
As a request, I really do like the clock centered, if you left it like that, or maybe a version without the clock being moved, I would be immensely happy.
Also, reporting these bugs
Ill fix the landscape view lol and what's wrong with the USB?
When I flash from recovery do I do it as an update or do I install it like a rom. Sorry for the n00b question first time using a theme. Thanks for all the awesome work! :D
Edit: Just figured it out. Looks great and work great too no issues so far. Any way we can get dialer and contacts next please. =)
OP will be updated in a few minutes, updated a bunch of stuff. But if anyone has any experience themeing, i need some help with the contacts/dialer. Im stuck lol
pm me i did ics for the admire i could probably help you out bro. whatcha havin trouble with?
Text changes are coming soon. Just need to figure out where to put this file. But I fixed the dark text in the settings ;) lol
With the USB it's just the button, I've noticed the button looking like it just got blanked out in a few other areas as well: The paperclip icon in the messaging, and a couple other buttons in apps that use system appearance (Alarm clock xtreme free as an example).
I got a screencap of the attachment button, and the transition as you're turning on wi-fi reverts to the original icon. Also, this with the charging icon.
Everything you've done so far is amazing. Thanks so much for the effort you've put into this, and I look forward very much to seeing what you'll come out with next
when installing this theme will it overwrite the permission and data throttle mod?
More then likely not lol make a nandroid first just in case.
Thanks! Ill fix them asap lol
