Root [THEME][MS870] Samurai Lime Theme
GameTheory
Android Expert
Samurai Lime Theme
Instructions:
---Place zip file in SD card
---Flash in recovery, no need to wipe cache unless you want to
** Warning **
For Samurai rom only. If you flash this on another rom it may not work as intended. You assume all responsibility for your device.
Downloads
Enjoy!
If you like this and want to show some support, please click the thanks button. :)
Thank you all. ;)
Theme just updated.
I made the notification area toggle buttons a little darker and more beveled to match better. Screen shot updated also so you can see change. ;)
Sweet theme, I can't wait for the yellow homie. Keep up the good work, it's much appreciated..
Theme just updated.
I think I'm gonna stick to the brighter green in the toggles. I really like it. Looks good though. :thumbup:
Decided to go with the green for a lil bit.
Yea BITCH!!
Homage to one of the best shows on television, so sad it's almost over..
