p-bOt
Android Expert
haha i dont know off top of my head man.. just look in layout and values folder..
alright thanks bro
bad download... wat rom you using?love the themeldrifta but my status bar keeps force closing
if any body can tell me what im doing wrong it would be greatly appreciated
thanks
yeah you cant theme that it's all odexed files loloriginal stock rom took all the metro crap out,
lol it's cool bro, like i mentioned in pm it depends what your looking for.. check out the sticky at top of thread and take a look at some romslol i did knowi told you im a new-bee
can you recommend one
i would appreciate the help
Hey drifta LOVE IT! Only problem I see is on the notification pull down menu some of the txt is black and barely readable. This is still my new daily driver though! Thank you!![]()
considering it...i would, if i were you, use UOT and add backgrounds to the notification (ics color just to keep up with the theme, and change the notifications text to black) because like you noticed, some apps notifications are in black text thus making it harder to read them with a black/transparent background. Or you could just change the pull down background too to a lighter color, although is so nice looking i wouldnt change it.
So after I go to install sip file. I find it click it and click yes? So that's how you flash it or not?
I am using ClockworkMod 5.0.2.8 How do I flash it on there?
