just did Enjoy everyone!!! updated theme, mainly for #2Any plans on adding settings mod to this theme L
Happy Holidays!!!!!
Yes... this is the latest one. Enjoy
yeah need to fix those and add latest patches from #2It's not the latest! The phone.apk and mms.apk are from #2
Where can I get this theme
I have this one installed on my phone and all I see is that the dialer numbers are white instead of blue and mms is from rom #2. No big deal.. doesn't bother me.What's wrong with this one
lol ill do it right nowhopefully he uploads the new updated theme soon.. i freaken love this theme it makes my phone look like ics.. im going to wait a little longer.. i dont want to flash this one and then tomorrow he uploads the new update..
when i install this on my phone running Rom #2 is slows my phone down so much helpZVD~THEME~ONLY!!!!!
MS910_LD-ICSK {ZVD}Flash at YOUR own risk!!!
ZVB & C are no longer supported.
Includes:
-Holo Launcher (Very ICS looking)
-ICS Wallpapers
-ICS Theme in system apps + framework
-ICS Window Animations
-ICS Swipe to Clear
-ICS Statustbar item layout
-ICS/GB Settings mix
-MT's Power Menu (with all needed files for screenshot)
~Very lightweight and compatable with MOST {ZVD} Roms
(But reccommended to be used with #2/LD-LG)
What's themed?
(Holo Launcher reduced the amount of required icon replacements LOL)
-themed System Apps + Framework
-download provider
-gallery
-keyboard
-dialer
-mms
-music
-settings
-added wallpapers
-volume sliders
-System UI
Download links: - Theme comes with THEMED Settings.apk, flash file below for BT Fix
LD-ICSK NO Launcher - DOES NOT remove or install any launchers
Battery WITH Percentage
Battery NO Percentage
BT Fix Settings CWM.zip - IF you use BlueTooth, you MUST flash this after the ROM
Installation Instructions:
*Installer-script is set to wipe Cache & Dalvik Cache
-Copy Theme [Zip file] to sd card
-Boot to recovery
-Make Backup!!
-Flash Theme [No Wipe Required]
-Reboot & Enjoy
Battery Saving Tips
Screen Shots:
Changelog:
v2.4
-Added 'S' to the title for discrepency reasons LOL
-Added/Updated ICS icons for both versions
-patched updater script for clean data/app install
v2.3
-Fixed broken music
-updated/fixed contacts theme..
-choice of launcher or not
-NO MORE BUILD.PROP
v2.2
-Updated system & framework with latest #2
-Updated some minor parts of theme
-More lightweight (less files included)
-Compatable with MOST Roms, but reccomend to be used with #2/LD-LG
v2.1
-Added Holo Launcher (Looks way better/More ICS looking)
-Updated build.prop to match #2 & LD-LG
v2.0
-All new updated look
-ICS statusbar item layout
-ICS swipe to clear MOD
-Updated Mms theme
-fixed download provider spinner lol
-more i forget..
Previous builds:
-Missing data...?
-Missing data...?
