Root [Theme] Nex Theme with a flavor of Blue
ThatOneDude05
This is a Blue version of Manup456's NexTheme for the Motorola Droid X. It is meant to be run on deodexed Froyo 2.2. Credit goes to Manup456 for the original creation and Fabolous for bringing it to the Droid X. I just added the blue from a Kangerade Theme for the Fission Rom thanks to a member over at Droid Life. (can't give a name due to the fission roms/themes being taken off of droid life)
If you are running Froyo, but not deodexed, consult these threads:
[HOW-TO] Manually deodex your phone. - Droid X Releases - AllDroid Public Board - [HOW-TO] Manually deodex your phone. - Droid X Releases - AllDroid Public Board - AllDroid.org > Home
Droid-X Clockwork Recovery image. Deodexed Rooted, Froyo'd - Droid X Releases - AllDroid Public Board - Droid-X Clockwork Recovery image. Deodexed Rooted, Froyo'd - Droid X Releases - AllDroid Public Board - AllDroid.org > Home
DISCLAIMER: I am not responsible for anything that may go wrong in this process - There is always the SBF file is something goes wrong.
Installation
Requirements: Rooted, Deodexed Froyo, Koush's Droid X Bootstrapper
1. Download file(s) and place the .zip files on the root of your sd card
2. Reboot into Clockwork recovery
3. Go to system and mount and mount system (should read unmount if done correctly) Just to be safe I would recommended this step.
4. Install .zip from sdcard, choose zip from sdcard
5. Install NexTheme Blue
6. ENJOY!
Im still doing a few things to it to make it perfect but that will be done with time is available. Let me know if you guys notice anything.
The second download link is for a little modded version of the Nex theme with a Blue Circle battery indicator.
Download Links: NexTheme_BLUE.zip
This is Version 2: http://www.mediafire.com/file/dlzzoi3a714kmkq/NexTheme_BLUE_V2.zip
Just switched a few little things like the clear lockscreen, easier to read font no more gray with white (hopefully)
Circle Battery:NexTheme_BLUE_BatteryMOD.zip
Yes, more pics please and does the circle blue battery change color as the battery gets low?
yeah once its gets below %50 it changes to a yellowish color then at %25 i think it goes to red. Im going to try and edit it so its all blue except for low battery status which ill leave at red.
Will you keep both versions? I'd like to have the three colors.
Does the circle battery zip only change the battery Icon, or does it change other things?
1Dude, can you confirm?
Are both zips the full theme just with different battery icons?
I think I may be confused.
NICE!! Of course, I must inform you that you are only feeding my already life-controlling addiction to modding my phone. :D Thanks!
More pics indeed.
Also, will this work with Fab's Apex ROM?
Yes, running the modded battery version now...not bad, runs just fine with Apex.
May be a bit too much blue for my liking, I just wanted the circle battery icon, but it looks like both zips are the full themes. Not much changed, Status bar icons are mostly blue and some blue highlights here and there.
Nice job Dude!
Nice job Dude!
Thanks man! Im glad its working good for you!
Great mod to a great theme....OneDude, whats the weather app you have running in the drop down? Thats pretty slick
Nice job Dude!
You can use ninja morph to change individual notification bar icons if you want to, I've changed a few of mine (battery, radio and up/download icons).
Cool, I'll try it later after work. What is the Rubix Cube looking thing on that last screenshot? Is that included in the theme?
This is a awesome theme! Thanks for making it.
I have a problem, when i try to download stuff from the market now it just hangs? Any idea's as to what the problem might be?
If you ever do a update to the theme could i make a suggestion? The boxes for open/install in the market are very light grey and its hard to see, if you made those white or black with white font it would be much easier to read. When using linpack the buttons for the run benchmark and other items are hard to read as well.
Just making a suggestion, once again congrats on making this awesome theme!
It's happening to everyone right now.
