Root [Theme] NexTheme w/ teenfaces StatusBar
D13
Android Expert
So this is a theme that I made by the request of pman219.
It is everything NexTheme except the status bar is this one.
I am not responsible for anything that happens to your phone
All credit goes to Manup456 for NexTheme and Fabolous for porting it to the X and the way I am setting up this thread:D
You have to be running deodexed Froyo to run this theme, to learn how to do that go to these threads
[HOW-TO] Manually deodex your phone. - Droid X Releases - AllDroid Public Board - [HOW-TO] Manually deodex your phone. - Droid X Releases - AllDroid Public Board - AllDroid.org > Home
Droid-X Clockwork Recovery image. Deodexed Rooted, Froyo'd - Droid X Releases - AllDroid Public Board - Droid-X Clockwork Recovery image. Deodexed Rooted, Froyo'd - Droid X Releases - AllDroid Public Board - AllDroid.org > Home
This must be installed through clockworkmod recovery so you are going to need to have the updated bootstrap recovery, which can be found here.
Then download the zip and put it on your sdcard, you can install it through Rom Manager by pressing install rom and then finding this file
Download Link
teenfaces_nextheme_v3
Screenshots
idk what either of those are :/ im running the 2.2 froyo leak. does that count as deodexed?
no check out the links in the OP
1. you need to install this app and open it up and press bootstrap recovery
then get rom manager and press flash clockwork at the top
bootstrap
2. in rom manager press backup
3. then check out this thread
Droid-X Clockwork Recovery image. Deodexed Rooted, Froyo'd - Droid X Releases - AllDroid Public Board - Droid-X Clockwork Recovery image. Deodexed Rooted, Froyo'd - Droid X Releases - AllDroid Public Board - AllDroid.org > Home and only restore system
4. then return here
on your sdcard there should be a folder called /clockworkmod/backup
in the back up folder create a folder called deodexed_froyo and put the contents of the file you downloaded from the alldroid thread into that folder
then...
the file that is 259mb? and put it into folder 'deodexed_froyo'?
yeah it is that big and put what is inside the zip file you are downloading and put all the files inside the zip file in the deodexed_froyo folder, then open rom manager and press reboot recovery
haha i feel so bad because your taking alot of time to walk me through this. and yes this theme looks awesome i hope it works. and of course thank you again :D
yeah I am just kidding, but sadly you know what has to happen at 2:30 don't you...I have to disappear again:(
so once you only restore the system of the deodexed froyo backup in clockwork you need to
1.download the theme zip in the OP and put it on your sdcard
2.open up rom manager and press flash clockwork then install rom from sdcard
3.find the zip and press okay
4.done:D
I think there should be a thread about how deodexing improves the speed of the sphone. And then everyone will do it know questions asked.
Great thread, Make sure and thank him incrediblenotinstock (click the little thumb that says thanks on the bottom right of his post.
