Aggie12
Android Expert
ALH designs posted a theme on here for Liberty 1.0 (og thread). I really liked the theme so I decided to port it some of the way. I wasn't able to touch the services.jar due to complications with working on a mac and colorChangev3.jar.
But I still think it looks good. It's really minimal in that not a lot was themed. If you find something you want changed please let me know and I will try to work on it. Or you can change it yourself and post it here. You don't need to give me any credit cause I didn't do much. Just clicked a few buttons and zipped a few files. lol.
Credit:
Themes
Install
But I still think it looks good. It's really minimal in that not a lot was themed. If you find something you want changed please let me know and I will try to work on it. Or you can change it yourself and post it here. You don't need to give me any credit cause I didn't do much. Just clicked a few buttons and zipped a few files. lol. Credit:
- Bouchigo & Faber: I used their base from BWC and overlaid aqua over it.
- GregTard for the Keyboard
- Alh Designs for the aqua theme for Liberty 1.0.
Themes
- ApeXAquA round battery
- apexaquastock.zip"]ApeXAquA stock battery
- Other pics
Additional:
Lowercase icons I used for text were from this thread:http://androidforums.com/android-themes/168855-icons-simple-text.html
The audio manager I themed on my homescreen can be found in the BWC folder. I left that stuff in from Bouchigo's theme because it has a lot of good stuff in it. Check out his thread for more information.
Install
- Already be running Apex v1.4 and have DroidX bootstrapper and a nandroid backup created.
- Download the theme you want above and place on the root of your SD card. This is the main area when you view files.
- Boot into recovery and navigate to 'install zip from sdcard' and click it.
- Click 'choose zip from sd card'
- it will be near the bottom. It's probably easiest to scroll up past the top so it takes you to the bottom faster.
- select yes.
- expect a longer initial boot.
It just upsets me. I was able to get the colorchangev3.jar to work before but not now. I just don't know. The hex code I'm using for the icons in the status bar is 039fc7. So whatever you can do with that would be greatly appreciated. Whenever, no rush.
