Root Theme Question
I have searched for this but didn't really find a clear answer. I am running BB Froyo 0.4---can themes be installed over other themes? IE- can I install blue energy over Xtheme? Is there a way to revert back to the generic BB with no theme or do I need to restore a backup to accomplish this?
you can put one theme over another but if the first one has more that is themed than the second there will be leftovers. Chances that the 2nd theme you are installing themes everything that the first did are pretty slim.
You can just flash the rom again without wiping and that would give you the roms stock theme back. If you have made any changes to /system they would most likely be lost though.
