Root {Theme} Red Galaxy Evolution EB01
nitsuj17
Android Expert
This is a theme that is based partially off of "Red Soul Evolution" from plasticdarlow at xda: original thread: [THEME]|Red Soul|Evolution|[12-03-10] - xda-developers
the status bar icons come directly from it...pretty much everything else is modded revolution icons/images by me
****EB01****
*Usual Disclaimer* I am not responsible for anything that happens to your phone. Best practice is to make a nandroid before flashing anything.
The status bar/icons and several other images come directly from Red Soul Evolution, but much of it was put together/made separate of the original theme.
Major Credit to: pasticdarlow at xda for the icons/images from his theme
sbrissen for 5 lockscreen mod/reboot options/acc battery/bat pop up disable
DtatchD for his status bar pulldown edits and help
manup456 for the base images from REVOlution
Changelog:
2.22.11: - updated base theme to v2.0. includes some fixed icons and apps
-added alternate aosp messaging cwr flashable zip (some dont like the sammy messaging from superclean) additional download below for it (flash it over the theme)
-added remove clock option that preserves red service.jar highlights and includes sbrissens batt pop up removal.
-REVOlutionary RED version added (its 2.0 just to stick with where the base theme is numbers wise)...basically just more red text...see the pics below for examples
Screens:
REVOlutionary RED Version: (a lot more red text essentially)
Cwr Install
V2.0 (regular): http://www.mediafire.com/?6o52gz3lde6k1kr
V2.0 (revolutionary red): http://www.mediafire.com/?y5gcozx9lgbdl7q
AOSP Messaging Version: http://www.mediafire.com/?sjjq68ta9t3b81e
Remove Clock: http://www.mediafire.com/?k56gtlorh4hk1kp
loving this theme! One question though: Is it possible to use the same messaging app that you used in the redbread theme? I like that one much better and the one you have included in this looks a bit pink and i dislike the bubble format lol. Maybe use red borders instead of the white around the contact pictures in the redbreak theme? I think that would look great!
Took me a second to realize there are now two red-oriented themes. This looks good but redbread seems a tad more red and thus I think I'll stick with it. Or should I say revert to it from nextang
I like redbread better too, but I'm also on tang now :D
