Root [Theme] Red Gingerbread for Liberty 1.0
SimsDelt
Android Expert
All credit for the theme goes to draya1986 from Droid Forums. I used the dock bar from Prophecy23 from here and edited his dock to fit this theme. All other icons I got from around the forums and edited them to match as well. Wallpaper was a simple change from yellow to black once I extracted it from "LibertyWallpaper.apk". Colors are the exact as the Georgia Bulldogs or Atlanta Falcons... I literally pulled the red from the GA Bulldog logo to make the reds, so its an exact match.
I take no responsibility for how this effects your phone or if it bricks it. Works fine on mine. Just follow directions. The theme here was developed for a D2, but does work flawlessly on a DX. As you can see with mine.
First you need to flash the Red Gingerbread theme:
Installation
  1. Copy Red_GB_Final_Liberty_1.0 to your sdcard
  2. Reboot into Recovery
  3. Install zip from sdcard
  4. Choose zip
  5. Browse and select zip
  6. Install Red_GB_Final_Liberty_1.0.zip
  7. When complete, use power button to back up
  8. Reboot phone
Phone may take a little bit longer to reboot, don't interupt it. Let it do its magic.
Second we need to go back into clockwork recovery and install the no throttle/no clock hack. (credit to atesc at Droid Forums) *** This will remove your clock in the notification bar, as well as remove data throttling... if you want to keep the clock, skip this step***
If you want to just remove data throttling, go here and download the appropriate file.
  1. Boot into recovery via clockworks bootstrap
  2. Select "install zip from sdcard"
  3. Select "choose zip from sdcard"
  4. Find and select "Liberty-1.0-noclock-nothrottle.zip"
  5. When complete, use power button to back up
  6. Reboot phone
****This boot will take forever... chill out... took my phone about 5 mins to boot up once it got to the Liberty Boot Animation****
The rest of the images and icons and dock are contained in the .zip file I have provided with this thread. Just use your launcher to add the dock background (I use launcher pro plus) and then change the icons in your dock bar to custom ones and use the ones I have provided. The center icon should be set to a transparent one (adding to the files at the bottom of the post.)
To keep everything clean on my main page I use "minimalistic text" widget for the clock and the two orbs are "Circle Launcher"... both of these are free. Love circle launcher because it keeps my selected apps handy, but out of the way.
I always recommend making a backup before you add a new theme in case you don't like it, especially if you will be removing the clock from the notification bar. And no, I don't know how to add it back, I'm guessing if you flashed the Red GB theme again it would rebuild the services.jar file and it would come back.
Hope this helps everyone. Enjoy...
Files:
Red Liberty.rar
http://www.mediafire.com/i/?29zreghdkde6140 <---- Transparent Icon
Red Gingerbread Icons
Also... if you like this and want me to edit an icon to match this theme for you, please just post it here and I will edit it, but I'm not gonna go searching for an icon for you and then edit it.
Very, very nice, Jonathan. You scored on this one! I'm going to flash it later. Thank you!
My home screen is even more clean now... went ahead and purchased the paid version of Circle Widget and made the "orbs" set to custom icon... and made it the transparent icon I posted above... now I just touch the screen where they used to be and my shortcuts come up... just nice because its even cleaner...
Love this! Would love it more if it were in green. Any way to get it in green, specificaly Kawasaki Racing green?
You should use the "Gingerbread" theme that comes with Liberty... I will edit the wallpaper and dock for you. I'm not gonna take the time to change all the icons I just put up though to green. I will do the ones I had already in the dock though. Give me an hour or so, my babies are running around like crazy.
That would be nice to see it in green. Take your time with this stuff, family comes first.
That would be most excellent. Take your time.
I did the best I could... the icons look a little neon on my screen, usually on the phone they are a little darker... I took an image of a Ninja and pulled the green off it. The wallpaper is dead on, the Icons might be a little off, but its the best I can do, I had to judge them by eye considering I'm editing the Hue instead of the color directly. Hope you like it. I edited the Icons, Wallpaper and Dock.
Kawasaki Green Liberty Icons/Wallpaper/Dock
Just remember to get the transparent Icon from the OP so you can keep the diamond area in the dock clear.
This is a bit of a novice question but your file is in .rar form and it usually is a .zip file to install a theme. What do I have to do differently to install?
Unzip that file and the contents are the dock/icons/wallpaper... it is not meant to be installed through clockwork recovery. The theme that will go with this is built into Liberty in the toolbox under Liberty Mods and Install Themes... its the top one "Gingerbread Theme"...
To use the files I created for you just unzip them and then search on google or the forums on how to customize your dock bar with whatever launcher you are useing... I use Launcher Pro, but others use ADW and I don't know exactly what the process is on there to customize ADW... the stock launcher that came with Liberty isn't customizeable... you could still use the Wallpaper I made for you, but thats about it.
Fantastic! This is exactly what I was looking for. Thanks!
No problem... hit the thanks button if I'm helping... I'm bored so I'm churning out all kinds of images here... but its still work...
I am looking after three of my little ones alone since my wife is at work so I have not had time to play around with it but this is what I have so far.
I sucessfully just edited my framework so that I have the lockscreen from Revolution Theme now... love it... its black and matches a lot better.
Awesome man... glad its looking good for you. Hope you are liking the wallpaper and icons...
