Root [THEME] Simple Blue 4.2, Simple Green 4.2 (10/26/11)
Bloodawn
Android Expert
Simple Green
Downloads
Simple Green 4.2(CTMod Froyo Only)
Simple Green 4.2(ShabbyMod 0.9)
Gingerbread Keyboard(ShabbyMod 0.9)
Swype Theme
Dock Icons(Go Launcher)
Wallpaper
If you don't like my font - Stock Font(Flash in CWM)
Simple Blue
Downloads
Simple Blue 4.2(CTMod Froyo Only)
Simple Blue 4.2(ShabbyMod 0.9)
Wallpaper
CTMod or Shabbymod and ClockWorkMod are required
Make a backup before flashing
Installation:
1) Copy the zip to your sdcard
2) Boot into CWM and select install zip from sdcard
3) select choose zip from sdcard
4) select the theme
5) select Yes
6) After it is done installing Press back button
7) Select Reboot System Now
To install the Gingerbread Keyboard: Put it on your sdcard and move it to /system/app and install it with a file manager then go to a text box long press on it and select input method and pick Gingerbread Keyboard
For info on changing the notification widgets click Here
Code:
[SIZE="3"][U][B]Changelog:[/B][/U][/SIZE]
[B]10/26/11[/B]
[B]Version 4.2[/B]
[B]ShabbyMod Version[/B]
Bootloop and Factory reset are fixed, flashing 3.1 first is no longer required
updated Simple Green scroll bar
[B]CTMod Version[/B]
Everything is the same except for the updated scroll bar in Simple Green
[B]10/22/11[/B]
Added a version of each theme for CTMod
[B]10/14/11[/B]
[B]Version 4.1[/B]
Updated the Carrier IQ removal to 3.1
Optimized framework-res.apk
Themed
-Talk.apk
-redid Contacts.apk for Simple Blue
-redid Phone.apk for Simple Blue
-redid the GingerBread Keyboard
Fixed blacked out text in Contacts.apk and Phone.apk
Fixed Bluetooth widget icon
Fixed some lockscreen alignment
[B]9/24/11[/B]
[B]Version 4.0[/B]
Themed
-Settings.apk
-Contacts.apk
-Camera.apk
-Gmail.apk
-Calculator.apk
-Mms.apk
-Phone.apk
Added and themed Gingerbread keyboard
New boot animation
Fixed some random bugs
Redid the whole framework-res.apk
[B]9/3/11[/B]
Removed Carrier IQ
[B]8/22/11[/B]
[B]Version 3.1[/B]
Added Simple Blue
Fixed a bug in contacts.apk
Updated zip script for EXT4
[B]8/20/11[/B]
[B]Version 3.0[/B]
Ported [URL="http://forum.sdx-developers.com/index.php?topic=12461.0"]CyanogenMod power control widgets[/URL] to work on the prevail
Removed title bar from power menu
Updated the contacts.apk to make it easier to read
Added more transparency to the notification window
[B]8/13/11[/B]
[B]Version 2.2[/B]
Added reboot options
Made notification background semi-transparent
[B]8/07/11[/B]
[B]Version 2.1[/B]
-Fixed the text color for pop up menu
-Fixed the tittle bar color
-Fixed a problem with the black contacts.apk call button
[B]8/06/11[/B]
[B]Version 2.0[/B]
-Optimized framework-res.apk
-Updated some images
-Themed Contacts.apk
-Themed more of framework-res.apk
-Included last updates add-ons
[B]7/29/11[/B]
-Modified [URL="http://forum.xda-developers.com/showthread.php?t=1028530"]This [/URL]swype theme to work with the prevail
-Changed the camera border
-Themed the stock keyboard
[B]7/24/11[/B]
-Added shabby's theme flasher
-Fixed some missing icons
[B]7/16/11[/B]
[B]Version 1.0[/B]
-Initial Release
Thanks go to Interdpth, Shabbypenguin, hroark13, 96blkgsr and he_stheone64
How did you get the time to display in white?
When I tried UOT Kitchen it and it didn't work for me.
So you edited all three of these xml files?
status_bar.xml ,
status_bar_expanded.xml ,
status_bar_latest_event_content.xml
I follow the guide but I only want to change the clock and it says it's going to change them all.
Any suggestions?
status_bar.xml ,
Any suggestions?
When you finish it theres gonna be a framework-new.zip, Open that up and take services.jar out. That is the file that has the clock color, The rest of the zip you can just delete.
Oh. So you only did the services.jar part.
then pushed just that file back into your theme
You didn't edit any xml files at all.
Update: Did just that part too and all is well. The clock is now white and visible. THANKS
Off to update my theme :)
I've tried yours & blue's work and I like them both ! Great work and a BIG Thank you ! :D
Ditto! Blood and Blue are both doing some impressive work. I used Blue's batch file instead of the Shabbymod batch and copied Bloods stuff into it. That way I did not mess with any ROM apps. I also skipped the Boot Animation as I like the one I have.
I do like the white on black look of the notification screen. Very easy to read.
The battery % is also a little easier for me to see
Good stuff!
Edit:
Not sure if this is related, probably not. something odd happened after trying out the two themes from Blood and Blue. I have not really done anything else to the phone that i blame it on.:
I somehow lost the sync with my gmail account and all my contacts. It was easy to fix. I added the gmail account back and it synced in my contacts. Maybe i deleted it by mistake, but it was weird.
Good stuff!
Edit:
I downloaded the updated version of ShabbyMod .09 and modified it . Worked perfect ! :D
OK, I had not looked at the StockFonts.bat file that Shabby posted. That is really the file that I modified also. I just copied it from the Blue update and modified it for the Blood update. Thanks again, Shabby!
trying to figure out where the boot animation is.... flashed it last night and it used the shabbymod boot animation
Open up the theme on your computer and copy bootanimation,zip from the media folder to your sdcard then use root explorer to move it to system/media, You can either overwrite the old boot animation or just rename it.
Thanks, Blood. Just put this on my new phone. The boot animation is pretty cool. I skipped it the first time around, but this is nice. Thanks for all the hard work.
