Root [THEME][WIP] p-bOtMOD ICS MINT(UPDATED 7/12/12!)
OP UPDATED!!!
added the edit text changer in the download links
flash as normal
I changed it to black cuz darker blue looked weird lol
enjoy :D
it Sucks that Ur Leavin Us :(
I'll be around man. :D I just have really shitty service in my new apartment. I have to use my phone alot for important stuff and I've been missing calls and texts because my service sucks I'm my apartment :( I'll be around here tho sooooo no worries :D
So does that just change all the text to black?
No it just changes the "edit text". That's any text that is inside a text field and you have to type yourself such as messages or passwords, memos and what not. All other text stays the same :) basically any time you use the keyboard it will now be black instead of the mint color :)
Well...I don't use Google voice but idk if this is my theme causing it. I don't see why my theme would cause this. Flash another theme and see if it changes and if it does tell me what color it changes to :) ill go from there.
Same thing happens with the 4shared app.
Font is white and background is also white.
ahhhh i see...well im guessing that it has to do with the secondary text color in framework-res.apk...but a quick solution would be to look around in that 4shared app because i think you can change the theme of the app to be dark...so that the background will be black with white lettering. :) i have no real way of fixing this because i no longer have an esteem to test on. :(
Well actually no. theme on 4shared can not be changed but guess I will work around it thanks for your help and the theme still is awsome
