Root [THEME][WIP] p-bOtMOD ICS MINT(UPDATED 7/12/12!)
UPDATED OP!!!
v.2.0.0
-fixed spinner issue in drop down bar when downloading
-changed USB icon
-themed mms.apk
-replaced all icons!
-fixed some things in framework-res.apk
-themed CameraApp.apk (still working on it)
-added ShinySide's smooth scroll mod
-replaced stock calculator with ICS calculator
-couple of other things I forgot.
-oh! and i kanged a couple of ldriftas system apks from ICK v2 to hold you off for a couple days while i finish the last few system apks lol.
Gotta love them updates...awesome :smokingsomb:
Hey You did a great on this and I noticed it was starting to slide back in the list so I thought I would bump it back up for you so everyone could see it as they need to!!!:D Awesome theme! WTG!!!
Hey You did a great on this and I noticed it was starting to slide back in the list so I thought I would bump it back up for you so everyone could see it as they need to!!! Awesome theme! WTG!!!
Thanks man!! I will be updating very soon with some stuff I'm pretty stoked about :D
Uploaded with ImageShack.us
The text is all white and not able to be read from the phone
Well...I don't use Google voice but idk if this is my theme causing it. I don't see why my theme would cause this. Flash another theme and see if it changes and if it does tell me what color it changes to :) ill go from there.
The text is normal white but the backgrounds are also a light color. Not sure if the phone's text is white also but you can change just the font color within the mms.apk.
Either the backgrounds need to be changed to something darker or the text needs to be made darker. ;)
the main text color in my theme is mint blue. unless google voice is using the secondary text color
Oh that's Google voice not mms? I've never used voce before but theme color shouldn't change Google voice color.
yeah thats why i told him to flash another theme and see if it changes the color and what color it changes to so i can figure out what text color it is using or if it is even my theme at all.
OP UPDATED!!!
v.2.1.0
-Themed LG-Contacts.apk
-Themed Phone.apk
-Awesome new text fields
-other shit that i forgot about but its awesome
-fixed framework-res.apk to work with ICS Gallery from PlayStore (check it out!!)
-more stuff that i forgot about lol
ok guys this thing is about done. I have a few more things up my sleeve but other than that its all yours :D
thank you for all your support!
oh yeah and there are a few more screen shots up so make sure you check those out!! :D
OP UPDATED!!!
v.2.1.0
-Themed Phone.apk
downloading right now ;) huge fan of this theme, my favorite
Is there anything I can do within Tapatalk to make this easier to see
yeah you can change the edit text in framework-res.apk/values/styles.xml
here is the guide i used
change text colors
if you want me to change it for you i can make a flashable zip wiith a new framework :D
ill just post it in the OP just in case other peeps are having the same problem.
do you think black would be better??
change text colors
If you could do that you sir will have my gratitude. My computer just got stolen :(
change text colors
I think just a little darker blue will do. I don't mind it but it is harder to see outside. Awesome theme by the way
