Fabolous
Superuser
Using ADW - Installed the Fabulous X _ CM6.zip from above. Tried uninstalling ADW first, but could not because it was running I assume. Any help is appreciated - thanks
You can find newer versions of the Launchers in this post here:
http://androidforums.com/tips-trick...-droid-x-themed-adw-launcher-launcherpro.html
Also, your CM6 may have come with ADW as a system app. If that's the case, don't worry about removing it.
