Root Themed .596 and certain mods not working together.
Sokudo Ningyou
I've got this red theme for .596, since I haven't bothered to install any roms yet. However, there's some mods I'd like to use as well, but they don't seem to play well together with each other or the theme: Bochigo's clock removal and CRT, and AirMaxx23's red honeycomb battery. If I flash any of them, the others stop working; the clock removal completely cleared out my red theme, the CRT off clears out the honeycomb battery and the clock removal. Is there a way to combine them, or do I need to take the files and manually copy them, and if so, where do I need to put them?
Bouchigo's clock removal mod is wrapped up with his own icons. Thats why it removes the red battery icon. Your best option would be to use Bo's clock removal and then use the UOT Kitchen on the web to make your own icons using your current framework.res and systemUI files.
Bo does have an all in one file that contains his crt mod, icons, and clock removal.
If you use the BWC clock removal zip or stock clock removal zip you will lose the icons from the red theme you are using, the ones associated with SystemUI.apk anyway.
You will have to manually make the edits to the xml files, or take my stock clock removal zip and replace all the icons in there with the icons from your red theme.
Same goes for the CRT and battery mods (affects framework-res.apk)
systemui.apk is one annoying apk, so much stuff that you have to pay attention to. :(
