RealNeliuz
Can i get the link to the wallpaper? Thanks
The carrier name is in /res/values/strings.xml of a decompiled framework-res.apk. There are a few instances of it for status bar, lockscreen and about/network. I made mine say Enigmanet![]()
I'm gonna start theming the LG motion little by little till we get recovery. Will be showing how since it requires a bit more work since we have no recovery.
If you guys want a different color just tell me, also what you would like to be themed and ill look into it.
First change just to see if it worked.
Stock Status bar black.
All black notification drawer with minor tweaks.
First remove the stock or black from systemui, than just copy and paste the modified systemui.apk in /system/app using root explorer and reboot.
Its easy and you won't brick.
Stock UI with black status bar.
http://db.tt/onOmbwGk
All black notification drawer.
http://db.tt/o9JGzDMz
I mistakenly posted instructions for GB. Look back a fewI can't find /values or /strings.xml under /res cause all it shows under /res is "images". Any help would be appreciated :thumbup:
What is the name im looking for to delete?
I mistakenly posted instructions for GB. Look back a few![]()
which colors? any more ideas? anyone? suggest anything and i will look into it.
Everytime I tried the kitchen I got SHTF error. I'm not sure they fully support ICS yet. The banner says Froyo and GB and the only mention of ICS is the battery mod.how did you theme? or how can i uot lg motion @ heriticsins. Bump
Finally some time to myself, I'm gonna try to see what I can do right now.
I'm having trouble getting systemui to decompile.
If someone can let me know if they got it to decompile, we need it in order to get a transparent status bar.
Can't do a lot of stuff without it decompiling.
What tool are you using?
Does this mod break stock messaging pop ups for anyone else?
