Root themers help me! :/
mjd515
ok i cant for the life of me figure out how to edit an xml...i can do alot of themeing my self but xmls make my head hurt..i have no idea what im doing if someone could give me a program to edit them and what to look for that would be awesome especially if you could give me info of how to edit the battery xml i would be very happy
You probably can't even open the xml because you haven't decompiled the apk you are getting the xml from with APK Manager......once you decompile you can edit it with notepad++ pretty easily.
ok so if i want to edit the battery xml i need to decompile the apk in apk manager and it will open and be readable?? im assuming ninjamorph does not do this/
