I don't use handcent but I'm pretty sure there's a setting in the app that disable double messaging. I highly doubt its the x cause no one is having this problem.
are the messages coming from people that are on another network in particular? i have seen that problem coming from certain other carriers.
So are you saying you're getting the message in both the stock messaging app and Handscent? If so, just turn off the messaging notifications.
Messaging / Menu button / Messaging settings / Text messaging / un-check notifications
disable/freeze one of the messaging app through titanium backup.. I'm pretty sure you have 2 different messaging app running at the same time as it happened to me.. for example for me i had (Messages 2.2.1) and ( [SMS/MMS PREFS] Messaging 2.2)
I disabled/freeze (Messages 2.2.1) problem fixed... hope that helps you
