autodefe
This is a post detailing what I learned the hard way. Or better yet, the things they don't really tell you in the main tuts.
- ClockworkMod Recovery Sucks IMHO and no disrespect to the devs, I just cant stand it.
- When you go to install a 2.3 ROM like aospCM7 from the stock rom, make sure to wipe everything before and after install.
- CWM Recovery selection button is the camera button
- ALWAYS NAND!
- ALWAY NEVER NOT NAND!
- Titanium backup is great, use it often to save your data usage if you dont have wifi
- If you can't flash the recovery from your computer, use a terminal emu. It has to be done after root and can be done with the same command lines
