Root think I am screwed, root went fine then POW
Lock-N-Load
Android Expert
did root tonight and all went well.
Last thing I did was a baseband update. but I did not clear cache/factory reset, and I had done a ROM backup earlier.
all was fine and dandy. was using phone. testing speeds. 45 minutes no problems.
Then I tried to go into ROM Manager and it kept closing. So, I just rebooted now is stuck on the M. I have not waited super long as normally it boots right up.
if I hold the X at startup I get a yellow exclamation point and triangle with a droid.
WTF happened? any help here?
Well, if you somehow lost your custom recovery - no idea how that would happen - you'll probably have to reflash the SBF using RSD and re-root the phone. Strange though.
**** now I am pissed
I can't even boot into anything. the M just sits there and holding the X just gets me to thats screen with the "!" point...
how do I even know if I have lost my "custom recovery"..
do not even know what "reflash the SBF using RSD" means
have I lost all my data? I made extra steps to Backup with ROM Manager and Titanium!
I am at a loss for what to do.. and no phone or data
I just pulled out my SD card and am now copying all the files. is there anything I can do to that direct and put it back into the phone and get it to boot?
No need to panic yet.
If you backed up when ROM manager and recovery were still working, then you have a working backup file sitting pretty on your SD Card. Chances are it's not going anywhere. You just need to re-root the phone.
Since you can't get into recovery to flash anything, and you can't boot the phone to use ROM manager, you'll have to use the SBF method. Go Here and follow the steps for rooting from Windows. It will give you a fresh rooted phone. You can then download ROM manager again, reflash Clockwork Recovery or SP Recovery (whichever you were using before) and restore your backup from earlier.
I admit I am in panic mode. tried to do everything right to avoid this, not sure how it could have happened.
do you mean this set of directions "How to Root 2.1 from Windows without losing app data"
BTW, I was using Clockworkmod and since I cannot boot into anything with the power + X trick, I assume that means something was lost? I do see a backup directory on my SD card when I examine it outside of the phone. and yes, before I did the baseband I did the backups.
Sometimes the recovery can be lost. I've had it happen a few times with older versions of Clockwork and the fix was to flash a different recovery in ROM manager, then flash back to Clockwork. Unfortunately, since you can't get into ROM manager you'll have to do this the old fashioned way.
And yes, those instructions are the correct ones. It will basically flash your entire phone with a rooted system and SPRecovery. Since you used Clockwork Recovery to backup, however, you'll need to use it to restore. So once you get the phone back up and running using those instructions, re-download ROM manager and use it to flash the Clockwork Mod Recovery. Once that is done, boot into recovery using X+Power, and you should be in Clockwork (all green text for reference), then you can just select Nandroid and restore your backup.
Make sure you follow all of those instructions precisely too. Don't want anything going wrong in this process. Don't skip the MD5 check, for instance. I know some people are tempted to do things like that and it can cause problems.
If you're at the command prompt in Windows, just type the following:
cd c:\
Or alternatively you can type
cd..
A couple of times until you're at C:\. That goes back up one in the directory structure.
cd c:\
cd..
got it.. and step 6.. I did not put step 6 file into root :( fixed that
Make sure that you did these two things..
A) You put the md5sum file in C:\Windows\System32
B) You put the SBF file directly on your C Drive. Don't put it in any folders, just right on C.
I hate to do this to you at this point but I have to get to bed. It's almost 2:30 AM here. I'm hoping that from here on out you don't run into any problems, but if you do, someone may be around to help, and I'll check the thread tomorrow when I get to work.
Good luck!
And yes, the flash can take a little while.
okay.. I got it to start step #10
it seemed like it took a a few trys to get it to go... but then it was quick and restarted.. but now, how do you "mount the droid" in step #12
got all the way to step #19 and.... when it reboots it just hangs at the M again
WTF :(
right up to reboot all seemed fine, everything seemed to check out and pass and now.. it is just sitting there with the M on the screen... only way to power off is to pull the battery.
is my phone just toasted some how... just like that??? I just dont know what to do next. what about all of the data - and backups - on my card. it seems to all be there, but.... no way to boot and get to anything UGH!
worst case scenario seems to have happened and I have no idea why. I thought i did it all correct.
now what? man, I am really really bummed :(
You are the second person I have seen this morning say they got stock recovery back which does not make any sense. If you havent already I would suggest flashing the 2.1 stock sbf file for now.
RSD says "phone failed security verification checks HAB error 0x8D"
and the phone says "critical error DEA1"
****! NOW WHAT
