I have the battery hooked up to my makeshift usb charger, its probably not doing anything, but i guess its worth a shot. The other verizon store in town is right next to my work and Ill probably drop in on my way to see if theyll charge it for me
buy a battery, long enough to get your X back on track, then return it and say its defective![]()
What do you mean by "makeshift USB charger"? Are you talking about those instructions earlier in the thread?
Because that doesn't charge the battery. It just makes the phone think the battery is full, when in fact it is being powered directly by the USB cable.
Yeah I was a little confused. so i hook the wires up to the phone itself?
Ok, using the red and black wires from a usb cable allowed be to get it into the bootloader and it said the battery status was ok and it was ok to program. So now I just need to attempt to sbf it.
it may have reviewed my anger history with technology and figured it might want to work correctly or it will be sent flying and break into several pieces while being urinated on, while gaged.... weird thoughts.
I hear ya. I have a bit of a temper when it comes to electronics that won't cooperate with me either. I tend to chuck things across the room.....lol
i chucked my xbox 360 controller and broke my 42" flat screen led hdtv because of call of duty 4 and some sniper that had aimbot. i should have left the game, but i was just too pissed to think
She lives. Im actually quite surprised the usb method worked. I was really nervous they would fall out in middle of the sbf... but no! worked like a charm. Thanks to everyone for all the help. I can relax now!
Glad to hear you have it sorted and the Frankenstein battery cable bit worked for you which I am admittedly too damn scared to try.![]()
in this same predicament.
when i get to the recovery menu, i just get the droid with the exclamation point.
none of the buttons are responsive.
