Help Think Juice Defender Ultimate is worth it?
i bought it.. now i never use it because it killed my battery alot more. so then i downloaded a widget to turn off and on my 4g. much better in my opinion.
ditto to that you can do all this thru setting as far as disconnecting data and 4g to 1x and the task killers all do the same thing imo
Best money I ever spent. I did a 24 hour test with it on and with it off with the general same amount of usage and the difference was astounding.
Different strokes for different folks though. best thing to do is try it. You can get a refund at any time, that whole 15 minute thing isnt factual. Ive gotten refunds months after the fact.
So your saying that I can get a refund now? After like a year? Lol
Agreed, I went a 2 without JD and 2 days with it(ofcourse on and off). By the end of the school day my battery was at 20%-15% but with JD it was at 40%-50%. :D
The best way is to turn off your data when your not using it. When i would leave it on my battery would be dead in about 7 hours tops. I would turn it back on every so offen to check email but that is the best and full proof way to conserve battery life (imo).
Using wifi when you can instead of 4G saves an ISH ton of battery. Turn your brightness down. Those 2 things right there will save you the most battery.
In the end the best battery saver is YOU!
thanks buddy!! ima try it :3 hopefully i can get my 5 bucks back lol
No problems. ;)
I recently switched Gmail accounts. So I wasnt about to lose ALL my paid apps. I went through and got 40 dollars worth of apps refunded immediately. Of course I turned right around and bought the apps on my NEW gmail but that shows you that google doesn't dispute anything. You want a refund? They will give it to you. ;)
Me personally I don't use it I don't like any kind of battery apps for some reason they don't work for me:-)
No problems. ;)
Wait how exactly do I get a refund? Give me your secret ways. Like how do I talk to them? Lol I just email them saying "oh this app isn't functioning well with my cellular device. May I get a refund?" lol
I try to keep my britness low but it's hard because I have a privacy screen protector on my phone
Yeah i tried one once and said bump that stuff.
I've prolly tried 5 different sellers on Ebay selling different screen protectors and FINALLY i found one that I liked. It literally feels like nothing is there and wouldn't you know they were the cheapest. 5 for 3.99 :D
im planning to get an anti fingerprint and anti glare one, 2 for $9 :)
Yeah Ebay is by far the best place to get cell phone stuff. Cheaply made parts for a cheap price. haha.
The TPU hybrid cases I use are 3.99 and my screen protectors are 3.99 for 5. It dont get much better than that considering Metro charges 10 bucks for ONE screeny and 20 bucks for a cheap ass case. No thank you.
Even OEM backup batteries. I just bought an extra OEM stock LG battery for 8 bucks. Brand new. Where as Metro and Verizon sell them for 25 i think. Money grubbing greedy snakes. Its a battery dammit! lol
Also amazon usually has the same stuff Ebay does with the exception.
They put it on my phone when I bought it.... It doesn't feel like it's the re but I people can't look at my phone when I'm using it... It's looks dark to them I love it
It actually drains ur battery. With the new ics and jelly bean os you don't need this garbage. It's the same thing with the anti virus programs.
I tried it, didn't like it.. to each their own though.. I just use 2x battery.. kills data once the screen is off and you can have it sync every so often to get your push notifications.. quick and painless..
Mine is using 9mb of memory right now compared to settings app just being open which is using 12 and Swype which is using 18mb.
It's not using that much battery compared to the x1.7 im saving from it. ;)
Plus the only time I've actually gotten it to show up in the battery usage section in settings is when it adjusts automatic brightness for you. Even then it was less than 2%.
