devilschild26
Android Expert
Ur SD card is safe just don't wipe external storage
Just thought I should mention this...
http://androidforums.com/attachment...ecovery-rom-guide-zte-awe-only-romastersu.zip a variant of Android/Spy.Agent.BN trojan connection terminated - quarantined Threat was detected upon access to web by the application: C:\Program Files (x86)\Mozilla Firefox\firefox.exe.
Rootmaster 1.3.6Accidentally installed the update for this phone
Root will no longer work. The King app just crashes and reboots the phone ;\
Any other ways to root or unlock the bootloader?
What thing did u click on b specific four posts up u will see a link that said root master click ithi it dosent work for me i click on the thing ur supposed to down load then it takes me to the log in page i log in and it down loads i click on it and it says can not open what do ido ??
The link I mention earlier read click and gain rooti click on romastersu.zip then it takes me to the log in i sing in and it pops up saying file name romastersu-7.zip under that it says file path under that it says cancle or ok i click ok it says in a box redirecting then says thank you for loging in then under that it says click hear if your browser dose not automatically redirect you i pull the bar down at the top of my phone where it says down load complete i click on it, it says can not open file then i click on ' click hear if your browser dose not take you automatically redirect you and nothing happens so ??
i down loaded that thing you told me to down load 4 post up what do i do after that ?
Are ur unknown sources checked if so install it well when u install and unknown sources are not checked it will direct u to the place to check click mulai root let it do it thing then click root again let it do its thing last click batal then reboot ur device u will see a new app its gunna b it super user it in a differ language loli down loaded that thing you told me to down load 4 post up what do i do after that ?
I just explaned it to u u have to install it then open the app follow the instructions I given ulol im so confused right now i dont know what todo lol i have the master one down loaded i open i cant even read it click on the midle icon cleck o+ something els then it takes a min or so then it just go white and thats it
It doing it wrong thenlol im so confused right now i dont know what todo lol i have the master one down loaded i open i cant even read it click on the midle icon cleck o+ something els then it takes a min or so then it just go white and thats it
