Where u from its 1:49 on my clockok lol still tryin to figure it out haha i started on this at 12 its 2 lol
Did u grant root permissionsthe root checker says my phone dose not proper root acces so?
Go to YouTube and put how to root using root master it will show uDid u grant root permissions
Its a one click method using an apk so yes its the easy way outIs this the easiest way to obtain root? I am just trying to run a data recovery program, mobisoft maybe, and it says i need to root first. I am not concerned with performace as this is an old phone. Mainly just want to recover deleted SMS.
This is the only forums for aweApk? Foreign to me. So basically just do step 1 from the op.ball from the phone? I want to install as little as possible so any deleted data doesn't get rewritten on. How about free data recovery? Does anyone know of this or is there another forum for i could read up on it?
Where did u get ur device from I got 3 from target and workedRoot Master no longer works on the ZTE Awe, or at least in my case. Had to swap out my phone a few different times because of some hardware problems, and Root Master worked every time prior. 1.3.6 doesn't work either. Once it tries to root and realizes it can't, it tells me to try to "cloud root" the phone or something like that and then brings me to a since deleted webpage. Do PC roots still work, or am I out of luck now?
W
Where did u get ur device from I got 3 from target and worked u may have to use a PC to root try saferoot apk
W
That's where u messed up target is the the spot I just got another one for 99 dollars and I rooted it in seconds I got it for the lollipop soon to comeDirect from Virgin Mobile. Must have been fresh off the line. I flashed the "L" Awe ROM fine though, so at least I was still able to do that. I just wanted to remove the horrible stock boot sound, which was the reason for me rooting in the first place.
This phone is bullet proof smacked it against walls still good lol well where I stay there isn't virgin mobile stores target and walmarts are my only options dessert status glad u got a ROM flashed now ur good to goNah, I didn't mess up. Got it for like $20 with $25 cashback. $100 is way too much for this phone.
http://www.datafilehost.com/d/f9d5b490Found the version of rootmaster I have Google root master modded scroll down where it saids key root master ( mod version) data file host down load that one installs supersu had some trouble pasting link
Thanks
Thanks ya the last link I posted wasn't the one I have looking at my apks it said key root master
