Root Three Step No PC Required Root,Recovery,Rom Guide [ZTE Awe Only]
Yep, you just have to transfer the file from your computer and then everything else takes place through the stock recovery
its a ROM that reverts back to b04 I have the ROM on my SD card already I'ma probably buy another awe for backup cus phenom work is great
I just wanted to note, that mine came with B05 out of the box, and the utilizes linked in the original post worked well, but required a reboot to take effect, for those interested.
Thanks for sharing the link. This is very useful.
Yeah its just basically the stock rom and I definitely agree with you on the phenom thing, he does great work
He is firing out so many roms, I can't decide on one to stick with.
There so much more in the works by June of next year there gonna be lots of lollipop licking happening (lollipop factory status)
This is exciting news.
I downloaded this Chinese root app. I think the app updated because I see no blue icons. Just an option to root, so I click it, and after a little bit, my phone just freezes then reboots. No root. Any tips...?
http://www.zteusa.com/media/wysiwyg/virgin-awe/update.zip download this ROM it will take u back to b04 place it on the root of ur SD card go in to stock recovery and flash the zip somebody correct me if I'm wrong once ur done attempt root method again
