I've been having some issues the last few days with my GPS locking in on my location. Was fine since I got it, now it just won't lock in. Anyone else having this issue?
very common issue--being addressed in the RUU that was just leaked
flash the RUU, or wait for the OTA (whenever that gets pushed)
OR
download something like GPS Status app and follow the steps to have it fix your reception. works for most users that have had the same issue.
Thanks, I'll try GPS status...just weird. Since I took it out of the box is was spot on, just crapped out all of a sudden.
I agree with Project. Install the new v2 update. Ive had 100 times less issues with GPS locking on when its "Cold" with it. Check it out.
"Radio:Multiupload.com - upload your files to multiple file hosting sites! Updated 4/19/11 @ 9:36PM
MD5: 8e166e93a9a72cb7955440720ba8869a"
[ROM] [04.18.11] BAMF Remix 1.5 - New base RUU plus more! *UPDATE* - xda-developers
+2 makes huge difference - for worse!! For the first time after reboot, i am waiting like almost a minute to get it locked. After that, its totally different proposition, it locks in, in about few seconds.+1
The radio upgrade makes a HUGE difference with the GPS.
No.Do you have to be rooted to apply the new radio?...
Thanks...
did you remember to rename the update to a .zip file?
yes I did...but I'm getting mixed answers though...some are saying I need to be rooted...s-off?
one download is for Rooted users,
one is for non-rooted users
might have just downloaded the wrong file--that's what's giving you the issues
No.
1. Make sure you are using this version of the RUU . XDA Forum thread on the signed RUU.
2. Rename it to PG05IMG.zip . It will not flash unless it's named this.
3. Put the zip in the root folder of your SD card.
4. Boot into hboot by powering off, then powering on while holding volume down.
5. hboot will scan for the file automatically. When prompted, confirm you want to apply the update by pushing volume up.
WARNING : THIS WILL WIPE YOUR PHONE! IF YOU ARE ROOTED, THIS WILL UNROOT YOU.
I downloaded the 25MB one?...
Any chance to provide the link to the non-rooted file please?...
Thanks...
Thanks for the reply...
I was just trying to apply the radio itself...not the RUU...
So I can't just update the radio by itself?...
It would be the same procedure, but I'm not sure why you would only want to update the radio. This is a signed image from HTC, so it most likely will be the OTA pushed to you in a few weeks. If for no other reason, you should flash the full RUU for the "Proximity Sensor's battery drain" fix.
