Root Tiamat kernel and speedtweak
tythunder
So i flashed Tiamat_Mecha v1. 1 kernel and i can see it in about phone. When i go to emulator though it brings up leankernal. How do I tweak Tiamat? I'm on cm7
You don't. Tiamat's kernel is undervolted stock and is not nice to overclocking. The speedtweak script is not built in. You can get setCPU from the market to OC but you may need to up the voltages so it doesn't freeze and reboot/bootloop on you.
Edit: Damn you Worm!
Hi,
Since tiamat is already undervolted is it more undervolted than tiamat kernel using speedtweak and setting it to option 1 normal or does it match up closer to extreme?
Thanks,
Bryan
Hi,
Thanks,
Bryan
Tiamat 1.1.5 doesn't need anything wrt voltages. Just leave it be and set your clock speed to your liking.
