Root Tiamat SBC and 3500 battery
i have used tiamat w/sbc and 3500 battery, it worked great for me.
Trying to figure out if you are trying to charge and it is staying on 0 or if it is on it's way down and stuck at 0?
I have heard about batteries being out of calibration and needing to be reset with new rom/kernel flashes, also heard it takes a few charge discharge cycles to settle down..
If you are trying to charge though, I think you might have a bad kernel flash, cause it is what is supposed to deal with the voltages. Also heard some phones don't like certain kernels.
