Ok, I've searched all over, and can't really find an authoritative explanation of what exactly "Time without signal" means.
You find it here:
Settings -> About Phone -> Battery -> Battery Use -> Cell Standby
Some people seem to think it means the time your phone has been unable to connect to a network signal, because your in a dead zone or something. If thats the case, a higher number is worse than a low number, it means your phone can't find a signal x% of the time the radio has been on.
Others seem to think it means the time the radio simple doesn't need a signal, and disconnects to save battery life. If thats the case a higher number simple means your phone is sitting there not connected or sending data for x% of the time the radio has been on. A higher number should mean more battery life.
It also seems most people, at least in the forums go with the first explanation, and think a larger number means more unnecessary battery use, and there are a few tricks to "fix" the issue.
But before I try to "fix" it, has anyone found a good explanation of what exactly it means? An explanation by someone who knows what their talking about, not just some kid who hit ## and some numbers and swears his battery life doubled.
And better yet, what about a good explanation of what cell standby is measuring. It says cell standby, but the description says, battery used by cell radio, which seems like all radio use, not just standby. Is the cell radio cover 2g phone calls and 3g data?
You find it here:
