Root Tiny tower not available in android market
Modman
Is this just not licensed for the esteem?
If I got it from another source would it work?
Or is it really not compatible?
Might try google for the .apk if it's compatible.
I bet it would work on the Esteem but the developer seems to only support a few devices that they deem to work good with their games. Check their website, they say 86 devices but they show a severalof HTC and Samsung devices only (and they dont list the 86 either).
I checked Android market and couldnt locate it, Amazon, nothing there, checked Best Apps and it went to the Android market and said it was not compatible, and AppAware shows file not found. Too bad :/
Email the dev,
When I published my own app I got the option to specifically choose what devices to include/exclude. I think he may have just gone a little overboard.
The other thing is this phone supports API version 10 or lower, so if he targeted a higher level API that's another reason why we wouldn't see it. If he simply excluded it, he may take off some of those restrictions for you. Part of the problem too is our phone isn't even listed on there yet which is kind of strange too.
My own app is made specifically for this phone, but I leave it open to anyone with any phone because there's a chance it may work for them also, I just put a warning to clearly let people know, and actually do have customers with different lg phones and even a tablet or two without complaints.
ok, so I found the apk and installed and it worked with no problems at all. But there is some kind of market type thing for the developer and it lagged big time! The game ran with no problems at all. I was excited about the game but got bored before I even built a 5th floor, so its gone. There was a folder that was over 25megs of crap left over after uninstall as well!
Even though it is a free app, with no paid version, I wont post where I found it but it was a very respectable forum from someone who was a rom dev. Just did a search for the apk, and found it within 5 seconds.
Yes its boring at first. But if you stick it out it picks up again. Very addictive.Think I got it from the same development site you mentioned.
