fcortes626
i managed to change the names and descriptions of the apps in the cstore to english. averything but one word is in english. i used google translate to translate from chinese to english so it might not be 100% accurate.
Screen Shot
Instructions
-Download the attatchen file to your SD card
-using root explorer copy the file to data/data/com.lewa.store/databases
-it will say file already exists do you want to replace?
-select yes
- set permissions to rw rw
-open cstore and it should now be in english. reboot and make sure it satys in english after reboot and you are finished.
Screen Shot
Instructions
-select yes
