Root [ TIP] POWER Button and CWM
wetbiker7
Extreme Android User
Hi people. I just wanted to let you guys and gals know that the power button can be used to select items in CWM in case you lose the touch feature.
If you already knew this then please disregard, if you didn't, then you just learned something new that may help you one day.
I just read a post were a member lost the touch function in CWM. I too have done this and had to end up using the power button to select FACTORY RESET. It's good info to know. LOL, I found out by trial and error. :p
Hope this helps someone. :D
I'm like you Jay. I'm kinda old school too when it comes to using the button. I always use the volume buttons to scroll and only use the touch to select or back up. Now that I've found out that the power button will select.... I'll probably start using it from now on. :-)
