androidguy1991
Member
Working WIFI Hotspot with Root:
1. Download a Rooted file explorer
(I used Root Browser free from the play store)
2. Download My HotsPot free from play store
(My HotsPot)
3. Open up Root Browser and navigate to /system/app
and delete HotspotProvision.apk and HotspotProvision.odex
4. Reboot your phone!
5. Open up My HotsPot app and you can config the name and password for the hotspot so no one else can connect or leave it open.
6. Click on open on the top right and it should open up the connection
Connect your laptop or whatever to your device and it will connect just fine!
Enjoy!
Issues:
If you are on a WIFI connection before you Open the connection will cause a FORCE CLOSE. Just hit OK and you will be fine.
It is best if you disconnect from any WIFI connection before you start the Hotspot.
(My HotsPot)
Enjoy!
Issues:
