or your data...
What do you mean?
hi Matt.
I've not had any issues. is it since last TB update?
I made a point of re doing my backup after last update.
for some reason I didn't trust it using previous backup when I was about to
stuff my hboot!![]()
You can flash dGB without touching the hboot. See how you like it and then do that later.
You know how sometimes you have a problem and then sometimes you wipe data and the problem goes away?
