Titanium backup/storage amount
Can someone make sense of the way titanium backup list the storage amount? what is this internal storage it list with a little less than 4gb total?
The 8gb internal is spread over the internal you mention, the locked app storage and stock apps / OS.
That 8gb internal.storage is represented by internal in the screenshot. The other 4gb is baffling.
Everything except "Ext. SD card" is part of the on board 8 GB. It is partitioned into 3 sections, but what I can't figure out is why three?
I believe that apps are installed on "Internal" by default. If you move an app to "SD", I think it is moved to the "SD card" partition in internal memory which means that I am still limited on how many apps may be installed.
As I understand it, the actual SD card is for media only.
