scudder
Android Expert
NOTE: Since writing about the issue below, I screwed up something UNRELATED to my Titanium restore problem which REQUIRED me to do a nandroid restore. NOT SURE if my problem below will be resolved with the nand restore, HOWEVER, if anyone has comments about the problem below PLEASE REPLY because (1) other people might be having similar problems and (2) I would like to learn what caused the problem and how to AVOID this problem in the future....THANKS!!!
Someone, somewhere once said you learn more by falling on your face. So, here I am again, brushing my face off...
So I partitioned my card (2048 MB), flashed MikG 2.52 and now I'm in the process of reinstalling my apps from Titanium. I have a bunch...I mean a bunch of apps that I have "archived" (uninstalled) with Titanium over the past few months and decided the best idea was to install pretty much everything and then go through, run and compare the programs and cull them that way because I'd be able to try them out and compare rather than try to remember what they did from the list of uninstalled apps in Titanium
Well, my "best idea" here has really turned into a SPECTACULAR idea (weee bit of sarcasm there) because it appears that my phone has sorta kinda lost the ability to restore apps from Titanium...
I had, literally, about 240 apps that I was batch restoring and just letting the phone do its thing while watching TV. I saw that the phone has restored about 143 and then noticed that it was STUCK on about 143...the progress bar wasn't updating. I had to force quit Titanium when the restore got "stuck."
I restarted Titanium and tried to restore just one, single app and THAT did NOT work...got stuck again. Sooooo, I got out of Titanium again, booted into recovery and decided...as is often suggested...to wipe cache and dalvik. Did that, restarted the phone and launched Titanium again. I again tried to restore ONE, SINGLE app and that DID work. So, feeling confident, I then set up another batch restore...NOT for the remaining 100 apps...but a reasonable 8 apps. I got through restore of THREE of those apps...then STOPPED AGAIN.
So, here I am....any idea what happened?? My sd partition size is 2048 MB...and now has about 1690 MB free so not even CLOSE to full. My internal memory is 213 MB free. Titanium indicates that I have 314 user apps installed for the batch app restore ceased working.
Is there an upper limit to the amount of apps I can have, even on a large partition?? Is there an upper limit to the amount of apps that Titanium can handle?? I'm kinda stumped! I did a nandroid backup juuuuuust before my "best idea" of attempting to batch-restore 240 apps so, worse comes to worse, I can revert to just a couple hours ago RIGHT BEFORE I started the batch restore...no big loss at all...but just trying to figure out what happened...to either fix it or avoid in the future.
THANKS!!
THANKS!!
