D doecon Lurker Jul 4, 2011 #1 Somehow I lost the bar that shows WIFI, Brightness etc. Is there a way to get that back? HELP, help..........
gallandof Android Expert Jul 4, 2011 #2 are you using Launcher pro, or adw? if so there should be any option under settings/preferences for the app
D doecon Lurker Jul 4, 2011 #3 I figgured it was an ap but I am really new to this and dont understand what you asked me. Appreciate any help I can get, thanks.
gallandof Android Expert Jul 4, 2011 #4 hmm first off, what phone are you using? and any custom software?
gallandof Android Expert Jul 4, 2011 #6 alright. have you tried removing the battery first? doubt itll help but a good place to start.
D doecon Lurker Jul 4, 2011 #7 Ill try anything (once). Doing the battery thing now........Phone rebooted OK but the control bar did not come back........
J juniorsabc Member Jul 4, 2011 #8 hold the the screen till u widgets the n you should see something call power or something like that it there u just dont see it
Gmash Extreme Android User Jul 4, 2011 #9 ^Yep, just long press an empty spot on the screen, and select the power control bar from the menu that pops up.
