Any reason this combo would'nt work??
Changelog for Shooter RLS_FinalV2
-Fixed Overscroll Glow Colors in Leedroid Tweaks (**Note-Leedroid Tweaks are not Fully complete, But working at leas 90%)
-Cleaned up Stuff here and there
-Removed more apps (they can all be found on your sdcard in the TeamNocturnal folder)
-Squashed Most all Bugs
-Fixed Hot Restart
-Fixed Restart in the status bar
-Added Nocturnal Wallpaper
-Decided against the Sierra Theme.....(I would like to see some people making themes.....So start Theming!!...lol)
-Updated all GAPPS
-Updated Sprint VVM to the latest release
-Cleaned up some stuff....Over 300mb on Fresh Install!!
**Note** If you find yourself starting to experiance lag run the a2sd nocache reset command via terminal. (after running the command you will still have wellover 200mb free space)
-Added Aroma with the fallowing options
* Sense 4.0 Clock (Thanks Bill)
* Stock Style MMS app (Not inverted)(Thanks Diesel)
* Rosie No Spin (Thanks Diesel Again)
* LeeDroid Tweaks Option (Do not choose colors fr wifi indicator your
status bar will fc allot)
* Sms Pop-Up (I have added this as an option cause many people dont like it!)
* Kernel Options are:
***Ca1nes Classic SBC
***Ca1nes Underworld SBC
***Chads Anthrax
***And of course simply Stock
Hahahaha Guess I should have read a little farther!And I was just reading the changelog for that rom
Code:Changelog for Shooter RLS_FinalV2 -Fixed Overscroll Glow Colors in Leedroid Tweaks (**Note-Leedroid Tweaks are not Fully complete, But working at leas 90%) -Cleaned up Stuff here and there -Removed more apps (they can all be found on your sdcard in the TeamNocturnal folder) -Squashed Most all Bugs -Fixed Hot Restart -Fixed Restart in the status bar -Added Nocturnal Wallpaper -Decided against the Sierra Theme.....(I would like to see some people making themes.....So start Theming!!...lol) -Updated all GAPPS -Updated Sprint VVM to the latest release -Cleaned up some stuff....Over 300mb on Fresh Install!! **Note** If you find yourself starting to experiance lag run the a2sd nocache reset command via terminal. (after running the command you will still have wellover 200mb free space) -Added Aroma with the fallowing options * Sense 4.0 Clock (Thanks Bill) * Stock Style MMS app (Not inverted)(Thanks Diesel) * Rosie No Spin (Thanks Diesel Again) * LeeDroid Tweaks Option (Do not choose colors fr wifi indicator your status bar will fc allot) * Sms Pop-Up (I have added this as an option cause many people dont like it!) * Kernel Options are: ***Ca1nes Classic SBC ***Ca1nes Underworld SBC ***Chads Anthrax ***And of course simply Stock
Everything except sd 3x and flash superwipe 2x then flash romwhat are you wiping?
