I just installed one as well. It is the best screen protector I have used to date, though i fucxed up and had to peel it off so I kind of messed it up a little bitI ordered a skinomi off of amazon for 10.00, it works great. Doesn't peel up on the sides from my silicone case. It's pretty easy to install. Just make sure the skin is completely covered with the fluid they send, and no dust, or lint on the screen. It has a great feel, and also doesn't make the phone look different at all, you can barely see it.
Eric
I have the Optimus S. Since the screen is fiberglass/plastic (it's not real glass) I decided to protect it. I bought an XtremeGuard screen protector from Ebay for $2.49 shipped and it's awesome. I used water to apply it like the instructions say, and after small amounts of water dry 1 or 2 days later, the screen looks identical with the protector on, versus when it had no protector.
