Root Tommy rom
Ok, so you are on Tommy's EVO Classic.
It should have the built in hacked sprint hotspot. Are you trying to use that or are you using a different tethering app?
can you explain what is happening when you say that your wifi tethering is not working? what does it do? it does not connect? are you able to see the phone's network? what are you trying to tether with? have you tried and wipe dalvik cache and cache in recovery? most small issues like this gets fixed by wiping the caches.
remember the more details the better we can help.
It's not working with my iPad like the data isn't loading...now I don't even think my wifi is working...I'm using tommys rom with the underworld kernel...and my battery is draining quickly and how do I get hdmi mirroring
ok not sure what you mean by data is not loading. does your ipad see your phone's 3g network and can u connect to it?
and the underworld kernel does have hdmi built in. you should not have to do anything other then hool it up to the tv.
