same hereTake your time, I'm very patient![]()
Success on swap! Props to lordvincent
Still in progress![]()
Yea, still can't get the /data part down... And the permissions are still not all setting correctly... I'm looking into it now but so far no luck... Right now it is a just a quick way to enable/disable swap and change swap file size/swappiness
@jwh- did you notice improved time in returning to the home screen?
Also, two part aesthetic question... 1.Can wallpapers be made scrollable with the stock launcher
2. Had anyone found a theme that changes the in-call wallpaper, or do i have to do it the ol' fashioned way?
I have noticed a little snappiness
So far the stock launcher has not allowed for scrolling. Switching to zeam does lol
If you go settings>personal>custom theme
At the bottom hit customize
You can pick and choose pretty sure the in call wallpaper is there
Does changing the theme change the icons in zeam?
And no to in-call wallpaper in that menu- lock screen, dialer & home screen wallpapers are there but nothing for the in-call screen
That's damn good! (if you compensate for the low write speed [+60 to +130] and the i/o [+55])
2327+60+55= 2442!!!!
2327+130+55= 2512!!!!
Anyone else not being able to send pics? For some reason I can't send pics with either 3g or wifi tried with normal messaging app and handcent any ideas?
BUT AS ALWAYS MAKE A BACKUP FIRSTInstructions
DOWNLOAD AND FLASH ZIP AT TOP OF THIS POST FIRST
First switch user:
SU
then create a swap file on your sdcard or sd-ext partition:
swapfileXX (size 12,24,36,64,96,128 on sdcard fat partition)
extswapXX (size 12,24,36,64,96,128 on data ext partition)
Then set swappiness:
swpXX (XX is swappiness in increments of 10 up to 90) errors in script are normal
swapfile-off (stop swap file in use) errors in script are normal,
clearswapfile (stops swap file and removes all swap files created) errors in script are normal
Swapfile at boot WILLWORK FOR SWAPFILE ON DATA-EXT,
bootswapfileXX (XX is swappiness in increments of 10 up to 90)
bootswapfil-off - removes bootswap
Is the file just called swapfile? Also where should it be placed?
I got some enable swap zips from my intercept. I'll send you link in minute so you can compare installer scripts
thanks thoNo it's all working now. Kouma got me squared away....thanks tho
o giggity. was it 06755 then?
unmount(/system)
Set_perm(
:banghead:No, copy paste error...![]()
Was beforeCode:unmount(/system)
Code:Set_perm(:banghead:
will this work on ctmod?http://db.tt/GkKjv9cI
This will use/create stl13(internal data partition) or a file on sdcard as swap
And give you options to create different sized swap files
Just install terminal emulator
And use these commands
Sry I'm not kewl like kouma, no app, but this would not have happened this soon without his help. He showed me my mistakes, and helped me get the data portion working (ok, he got the data portion working, because I'm slow and have fat fingers and make typos) thanks kouma you tha man![]()
