Root Too late for MIUI Gingerbread?
I'm having trouble installing flash I downloaded the 10.2 found in this thread but also the one linked here to xda any idea I try installing it but says not installed I tried to both internal and sd
flash ain't working for this rom
Sure it is...
Try this one
http://db.tt/O2fCAIuO
Am wondering if anyone can help with this error I am getting while trying to compile cm...A little new to most of this so just need a little guidance in the right direction....
I am running linux mint 12 in this compile attempt.....:trytofly:
clared (first use in this function)
hardware/libhardware_legacy/wifi/wifi.c:730: error: (Each undeclared identifier is reported only once
hardware/libhardware_legacy/wifi/wifi.c:730: error: for each function it appears in.)
hardware/libhardware_legacy/wifi/wifi.c:730: error: expected ')' before string constant
hardware/libhardware_legacy/wifi/wifi.c:730: error: too few arguments to function 'strncpy'
hardware/libhardware_legacy/wifi/wifi.c:735: warning: implicit declaration of function 'wpa_ctrl_recv'
hardware/libhardware_legacy/wifi/wifi.c:738: error: expected ')' before string constant
hardware/libhardware_legacy/wifi/wifi.c:738: error: too few arguments to function 'strncpy'
hardware/libhardware_legacy/wifi/wifi.c:748: error: expected ')' before string constant
hardware/libhardware_legacy/wifi/wifi.c:748: error: too few arguments to function 'strncpy'
make: *** [out/target/product/prevail/obj/SHARED_LIBRARIES/libhardware_legacy_intermediates/wifi/wifi.o] Error 1
make: *** Waiting for unfinished jobs...:confused::confused::confused::confused::confused::confused:
o370
I will help you
head over to this thread, and tell me what you have done so far
http://androidforums.com/galaxy-pre...ut-building-cyanogenmod-7-prevail-source.html
You just put a big smile on my face :D thanks B-love
But it still has the 'roaming indicator off' thing in the notification bar -___-
Haha..so I had the xml changed to display "Miui" but I decided to take it out. With all the talk of phone security I figured it would be a good place for a emal address or might encourage people to individualize there phones more. I agree that it is very annoying and something simple enough that everybody should have a unique display ;)
Is the cell signal icon still not working or is it just me having poor service?
I'm at the office right now, and i was wondering because i am trying a different prl so it could be the prl.
Its just not reading correctly
I even tried a widget to show dbm, but it shows -120 and i had 'perfect service' (-65 on other prevail right next to mine)
I do have service tho, (sorry for confusion)
One of the problems of not having service on the device..so its working correctly just not displaying or are we noticing full signal loss
so you guys are having trouble with the signal of 3g showing correctly?
like no signal on indicator or widgets but signal is working fine?
