but, I have downloaded the boot.prop file.
I am trying to follow these directions:
Method 2 - Root Explorer
1. Copy the build.prop to the root of your SD card
2. Long press on build.prop
3. Select "Copy"
4. Navigate to /system
5. Click R/W in the top right corner
6. Paste, and overwrite
7. Reboot
I cannot locate the /system folder. Any help?
3. Select "Copy"
7. Reboot
Glad you asked it.. I'll move this to the root section for ya and will look over your shoulder to make sure it gets answered!
