Help touch wiz issue
In homescreen,
Tap Menu/Add/Shortcuts or applications....
And you can add shortcuts/applications into the homescreen and from there drag it into the dock.
In application drawer, long press on the icon and drag it to the homescreen. From the homescreen, move it to the dock. You can skip the part about placing it in the homescreen first of course. But I think its easier just to have everything in the homescreen then readjust for the dock from there.
Cheers
In homescreen,
Cheers
drag and drop from homescreen only gives option to remove,unless I'm missing something.
It does....
Oh well... Been using Go Launcher for so long that must have forgotten that part is not the same as TW. Will test it out later.
Sorry... I made a mistake. In TW, have no idea how to get the docks to work. In fact I have 4 icons on the docks and I don't even know how to change it. Like I said, been using Go Launcher for so long, didn't figure that TW could be so different.
Sorry couldn't help.
Here is how:
1. Open the app drawer
2. Then press the menu capacitive key and EDIT. It may ask to switch view type (I'm on a different phone). Choose switch
3. Drag any app you want in and out of the dock (home can't be replaced)
4. One done press the menu capacitive key and select save.
:D
Great.... Happy you solved it. You should try some of the other launchers. Would take time to set up. But I feel its better than TW after using for so long.
The only advantage TW has is the app drawer is one of the neatest. Also its the leanest launcher.
Anyway, clear data would also reset your settings and widgets / shortcuts won't it?
Cheers
Yeah it did reset all the widgets, but the main thing was the dock bar went back to normal i also use go launcher i think its great but touch wiz is a bit more smooth to use
