Hey People of the internet. I've been using this forum on and off for a while to root my phone. I just found out about the ICS/quattrimus rom so I wanted to give it a go. I had a few issues at first, just to give some background, but nothing I couldn't figure out with the help of these forums and a few other android forums. Anyways so I've formatted an sd ext partition, wiped and all the stuff, flashed from the zips all i needed. and went to load it up. I don't think I did it right at first because it got stuck at the AOKP unicorn screen. Ps, that's the version of the quattrimus rom I flashed. But then I booted into recovery, used a wipe zip i had, reflashed, and presto. Worked like a charm for a few hours. This was say about 3 am before I crashed out. I decided to look for bugs.... and everything I wanted/needed worked perfectly. I even overclocked with no restarts/freezes. Once I had all the apps I wanted i went and made a back up. And restarted again and it worked fine....
Now to my problem. SO about 7 hours later. My phone's touchscreen hasn't worked at all. All the buttons work. the rom looks to have loaded fine. I can even take a screenshot, but I can't do anything. It wasnt wet when I woke up or anything weird. It was lying face first down on a DRY towel when I woke up. Fell off the bed about 8 inches onto it, which made me think maybe thats the problem, but theres no screen scratches or dents, cracks etc. Any suggestions? So far I've reflashed it with no luck. I tried to factory restore my from clockwork mod, which did nothing but get my phone stuck in a blue screen. Then i just reflashed and Im back to my current problem. Help? lol.
I was thinking it might be a kernel problem.... my clockwork mod might be too old? I clearly have no idea. So any ideas or questions that may help get to the problem would be much appreciated
