Help Touchscreen problems?
Yeah, that can potentially fix your phone, provided you can get a hold of a factory firmware image (a tot file) and dll for your phone. We have a process for this for the original Volt, but only because one of our members shelled out $100 to buy the firmware image from LG. Try looking for a Volt 2 tot file. Don't know if you'll find one, but it's about your only option now. There's the possibility you could sneak it through LG for a warranty replacement, but that's assuming they don't bother to check for tampering.
Thanks again everyone for all the help. I didn't yet succeed but I learned a TON..
I came here because my LG Volt 2 touch screen completely stopped working 2 days ago. I did the soft reset of removing the battery and after several attempts with no results I decided to do a factory reset. Once I did that it got stuck on the Activation screen so, I Googled "touch screen not working" and here I am. I have read this entire thread and I was thinking there may still be hope.
I am a bit confused as to whether or not I can download Kingroot, Flashify, etc. for the LG Volt 2 or if that is only for the LG Volt? Are those links to those downloads up-to-date? If anyone can help I would greatly appreciate it. Thank you in advance.
My wife and I both have occasional touchscreen problems with our LS740 Volts. Usually though it's false touches. IOW we dont tap anything but the phone does it on it's own. We also find settings occasionally change all by themselves. For example Wi-fi turns itself off maybe once a week.
