^^ what he said. Buy 4ext you won't regret it
you dont have to buy it if you are a XDA member
Someone correct me if I'm wrong but can't you get a free version straight from 4EXT Development that just has less features than the paid version?
OK by member you mean just having an account. I thought that version didn't have full features
OK by member you mean just having an account. For some reason i thought you meant paid member. Does that version have full features
Just got done using the 4EXT Updater (free version). Sounds like it can only install and update the 4EXT recovery, which is honestly all I needed. Thanks for the help everyone, I may end up buying 4ext control...we'll see
as far as I know , 4ext paid only adds a app that you can use within the phone. besides recovery
If you don't want to pay the three dollars for 4EXT Recovery Control, which is well worth it IMO, you can download the Recovery Updater app from 4EXT Development and install it as an apk. It will provide all of the functions of Recovery Control app for a three day trial period, then revert to the basic functions that allow you to update and configure 4EXT recovery.as far as I know , 4ext paid only adds a app that you can use within the phone. besides recovery
You can use Aroma File Manager for that. Just "install" it as you would any other zip file and you will have a file manager that is more powerful than the one in TWRP2. It doesn't actually install as part of the recovery so you have to start it with the zip file every time you need it.I love 4ext except it needs a file manager so you can move pgimg files! Lol
Works with any custom recovery, even the non-touch versions.
ramjet73
If you mean utilities that run in recovery, I don't know of any other full blown apps like AFM, but there are utility scripts like the ones to reset the mainver and unlock/lock the bootloader. Once you learn a little bit about Edify and shell scripting, there are actually a lot of things that can be done from the updater-script in an installation zip file, but that's not as "user friendly" as AFM.Wow, that's awesome. Thanks for the tip! Any other cool utilities like this?
ramjet73
I'm only trying to help out here since there are no Evo V 4G specific forums on XDA and I want to be able to provide support to VM users for my rooting and S-OFF guide there.He's everywhere
There are a lot of very knowledgeable people here, and we all learn from each other.
ramjet73
ramjet73
