Help Transform's internal memory is in read only mode.
Not even sure how to address this. I noticed that my phone for some reason wasn't rooted anymore. Prolly due to an update. when I went to try the one touch root, the ch-mod was in read only mode for internal storage. Anyone know how to fix this?
Sorry, I haven't rooted a phone using this guide yet but others report everything works. I suggest posting your problem in the guide/thread so that someone more knowledgeable can help.
Yay! I figured it out!
So here was the issue. The 1 click method was obsolete and was disabled with an update to make it not work anymore from Samsung. However, The older version of superuser was still in the phone. This either caused a conflict with the updated superuser rooting method, Or, Samsung designed an update to put the phone in read only mode when the older version was still installed. In either event, I had to use the boost unroot to clean out the older version first and then root it again with the updated root, success!
Thanks Mydian! I got working flash and hulu apk's if you need them! hulu apk works on any device (or so I am told)
night!
