"Transition" is the best way I know how to describe what's happening. I recently upgraded to 4.0.4 but I noticed that after the update, when I am sending an SMS and use XT9 there is a "fade" or "lag" with every word I type. If you have the "word completion" and "auto substitution" options checked for XT9, you'll know how the words usually appear in a bar above your message for you to select the one to complete the sentence. After the update, that bar appears with every word I type, then fades to disappear when I hit a space, then reappears again. The constant fading is giving me a headache and I finally had to turn XT9 off completely. Has this happened to anyone else or is there any way around it other than just disabling XT9? I'm sorry if the description isn't clear enough. I can try to provide screenshots if that would be more beneficial.
