Root [Transparent] For Number #2
no themes. stock number 2 beta 3 and yes i used that zvd tool took me about 27 min to install it.
do u want me to send u a copy of my framework-res and compare it to see if theres any difference or perhaps mod mine and see if it works?
yes send me yours so i can figure out whats going on.
Another thing i do is download the apk files i want to be added to the system and update all the apk from the store and place them in the .zip before flashing, that way i'll be ready to go from start.
But another way to add all of your apps,call log, sms and all, just backup your rom than flash the rom of your choice than reboot into recovery and go to advance restore and restore just the data, and bingo.
Been doing that for the last 3 ROMs I've flashed, and it works MUCH better than TiBu... faster, and far more complete.
For someone who's not rooted, I can understand... but if you have root, and CWM - the choice is obvious.
And to that note (where I first learned it) - thanks PG!
(and thank you too nuttmeg!)
